Thread: Purge Page setups
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Purge Page setups
    Is there any way to do this?
    I used a template from home to create a title page at work, and it keeps setting all my pages on the automatic printing to the missing printer.
    (Using ASD and it is very odd in how it lets you print, but if I can remove the apparent default setup, it might actually print my sheets properly.)
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    Earth
    9,803
    Default Re: Purge Page setups
    You can select and delete page setups from the Page Setup dialog.
    Page setups are stored per-layout in the drawing, so there is not really anything "setting your pages...to a missing printer"
    R.K. McSwain | CAD Panacea |
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by Katika View Post
    Why not import the correct page setup, set the layout to use that, and then delete the bad page setup? This is all possible from the Page Setup Manager.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-07
    95
    Quote Originally Posted by RobertB View Post
    Is there any way to delete more than one at a time? I have a set of drawings that has a TON of page setups in it and I'm tired of having to scroll through them when I need to use a different page setup.
    Earth
    9,803
    Quote Originally Posted by kkimberlin View Post
    Highlight one and hold down the DEL key.
  1. Page setups - how many is too many?
    By gilmer in forum CAD Standards
    Last Post: 2008-05-31, 06:54 PM
  2. getting page setups
    By jakob_k in forum AutoLISP
    Last Post: 2007-10-03, 06:05 PM
  3. Is it possible to purge page setups, from the plot dialog box?
    By john.103073 in forum AutoCAD LT - General
    Last Post: 2006-04-05, 08:51 PM
  4. Page Setups
    By cadmecheng in forum AutoCAD Plotting
    Last Post: 2005-08-07, 11:14 PM
  5. Missing Page Setups in Page Setup Override
    By footprint_arch in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-15, 08:41 PM
