Thread: Find arc radius given length and chord
    2015-11
    Waxahachie, Texas
    137
    Default Find arc radius given length and chord
    Does anyone know how to draw an arc when only given the arc length and chord length?
    I know that the chord length is 19'-4 1/2" and I know that the arc length is 24'-8". How do I find the radius?
    Any help would be greatly appreciated.
    All AUGI, all the time buzz's Avatar
    2007-10
    Tucson, Arizona
    613
    Default Re: Find arc radius given length and chord
    See if this helps: http://norman.rasmussen.co.za/24/rad...-chord-length/
    (via my good buddy, Google)
    -Buzz
    no trophy, no flowers, no flashbulbs, no line,
    he's haunted by something he cannot define...
    102
    From the wizard known as _gile:
    ;;; ArcChord->Angle (Newton method) by _gile
    ;;; Returns the arc angle according to its chord and length
    (defun ArcChord->Angle (arc corde / k x)
      (setq k (/ corde arc)
            x (sqrt (- 6 (* 6 k)))
      (repeat 6
        (setq x (- x (/ (- (sin x) (* k x)) (- (cos x) k))))
      (* 2 x)
    ;;;Testing command
    (defun c:test (/ chord arc ang rad)
      (while
        (not
          (and (setq chord (getdist "\nLength of chord: "))
               (setq arc (getdist "\nLength of arc: "))
               (< chord arc)
        (prompt "Try again -- arc must be longer than chord.")
      (setq ang (ArcChord->Angle arc chord)
            rad (/ chord (* 2. (sin (/ ang 2.)))) )
      (prompt
       (strcat "\nChord length = " (rtos chord)
                "\nArc length = " (rtos arc)
                "\nRadius = " (rtos rad)
                "\nAngle = " (angtos ang) )
  1. delta radius length tangent lisp
    By mgonzales361438 in forum AutoLISP
    Last Post: 2014-06-11, 07:52 AM
  2. How to find the length from the start point of a polyline?
    By pferreira in forum AutoCAD Tips & Tricks
    Last Post: 2006-07-10, 03:36 AM
  3. Arcs by P.C., arc length, Radius, Tangent bearing, Delta
    By justinxxvii in forum AutoCAD General
    Last Post: 2006-04-29, 10:32 PM
  4. Dimension Radius Length
    By matt.bauer in forum AutoCAD LT - General
    Last Post: 2004-12-21, 02:28 PM
