Thread: snap crop view (region) to drafting lines or reference planes
    2009-04
    18
    Default snap crop view (region) to drafting lines or reference planes
    It seems the crop region can't snap to any line/reference plane. I hope there is a work around. Any idea? Thanks!
    2004-05
    Auckland, New Zealand
    341
    Default Re: snap crop view (region) to drafting lines or reference planes
    You can snap to the Bottom Left Corner of a Line, and draw a line from the Bottom Left Corner etc.
    2009-04
    18
    Thanks Dwane! After some further testing, this is the way I find to match crop view region exactly exactly as the rectangle of drafting lines. First, you drawing the rectangle using drafting lines and write down the dimension of length and width. Then check "Crop View" and "Crop Region Visible" in View Properties and then set the size of crop region to be the same as drafting line rectangle. Then select crop region, pick the low-left corner and snap it to the low-left corner of rectangle.
    Do not check "Annotation Crop" option as this will stop you picking the low-left coner point of crop region.
    The reason I need to match crop region and drafting line rectangle is that I need to export same view to be DWG and image JPG seperately (in Hidden line and Shading mode seperately). And then in AutoCAD I put the JPG underneath the CAD lines. So I need the rectangle in CAD to scale the JPG exactly to match CAD. This way I can get perfect color pdf with shadow from AutoCAD! Revit pdf output sucks when making shaded pdf. I don't know if anyone else have other work around to create color-shaded pdf with sharp lines from revit, please share. Thanks!
  1. Difference between Reference lines and Reference planes
    By adnama in forum Revit Architecture - General
    Last Post: 2009-10-28, 04:39 PM
  2. Snap view crop regions, viewports, and view titles to reference planes/line in titleblocks
    Last Post: 2007-09-27, 02:15 PM
  3. Crop Region/Reference line and planes?
    By ykang in forum Revit Architecture - General
    Last Post: 2006-12-06, 07:23 PM
  4. section view crop region doesn't snap
    By clarkitekt in forum Revit Architecture - General
    Last Post: 2006-08-10, 09:51 PM
  5. 8.1/N Drafting Reference Planes
    By Andre Baros in forum Revit Architecture - Wish List
    Last Post: 2006-04-12, 03:42 PM
