Thread: Copy items from Arch Model
    2008-07
    Brisbane
    349
    Default Copy items from Arch Model
    This might by old news
    If you have an Arch model Linked in to your Struct model you can actually select items (columns, slabs, roof etc) in the linked in Arch. revit file and copy them into your model. I have done that now for a few projects to get the columns, slabs etc in the same location as the arch. – it is way faster than draw them yourself.
    It is similar to C/M but without the monitor option.
    J
    2007-03
    147
    Default Re: Copy items from Arch Model
    The linked file, bind it and explode.
    2008-07
    Brisbane
    349
    Why would I want to bind and explode the Arch model? I don’t want all of his “stuff” in my model – I only want the struct. geometry such as slabs column locations etc.
    J
    2008-11
    Australia
    754
    Yeah I have done this before but mainly for stairs etc which dont copy/monitor at all.
    I would think you would be better off using C/M to start with then just select all and unmonitor it. its a bit easier and you can set up views to show just columns or whatever it is you need from the file...it also takes away that possibility of slightly misaligning it when you paste..
  1. Replies: 3
    Last Post: 2015-08-25, 05:23 AM
  2. 2013: Best practice for bring Millwork from the Arch. model into my kitchen design model?
    By dmitchell404334 in forum Revit Architecture - General
    Last Post: 2013-11-19, 07:19 PM
  3. Replies: 0
    Last Post: 2011-10-07, 08:38 PM
  4. 2012: Add items to Catalog - Autocad Arch 2012
    By Falcone in forum AutoCAD Customization
    Last Post: 2011-09-02, 05:24 PM
  5. Unable to copy arch wall previoulsy deleted in struct model
    By myBIMhero in forum Revit Structure - General
    Last Post: 2010-08-22, 02:58 AM
