Thread: Invisible door
    Turlock, CA
    5,761
    Default Invisible door
    I have a wall that has an opening cut in it, but the door that cuts it won't display. How can I select it so that I can delete it? I think the problem started when I changed the wall's rotation in properties and the door didn't stay anchored properly.
    C:> ED WORKING....
    2007-12
    221
    Default Re: Invisible door
    Can you post the drawing file so that we may take a look?
    Turlock, CA
    5,761
    I left it zoomed in to the door in question.
    C:> ED WORKING....
    2006-12
    Big "D"
    3,711
    You have that particular door on the Xref layer for some reason. Thaw that layer and it will show up.
    Why is it called common sense when it is so rare?
    RevitForum.org
    Turlock, CA
    5,761
    I never thought of that (obviously). I used "Insert Selected" so I have no idea how it got on the xref layer. My mind was focused on thinking it was an ACA issue.
    Thanks
    C:> ED WORKING....
  1. Invisible Lines For Door
    By SCOWBOY74 in forum Revit Architecture - Families
    Last Post: 2011-06-23, 04:34 PM
  2. Invisible DWF?
    By tiffany.amorgan in forum AutoCAD General
    Last Post: 2010-01-08, 08:50 PM
  3. Invisible DWF
    By tiffany.amorgan in forum AutoCAD LT - General
    Last Post: 2009-06-09, 01:33 PM
  4. Invisible line shouldn't be invisible
    By WolffG in forum Revit Architecture - Wish List
    Last Post: 2003-12-19, 01:23 PM
