Results 1 to 10 of 10
Thread: Converting .shtx fonts to TrueType for 2010 ACAD and Revit
    2010-02
    11
    Default Converting .shx fonts to TrueType for 2010 ACAD and Revit
    So, our office has a few stations up and running in AutoCAD 2010 and REVIT 2010 software. It is my understanding that both of these programs recognize Truetype fonts only.
    Now, our office has used Monoarch.shx forever, and it is my undeerstanding that this was a font that came through with autocadd many realeases ago, andI’m sure many users have and had this as an office standard font.
    What we would like to find is a TT Font that equates to this .shx font, so that we can use this TT Font in both ACAD 2010 and REVIT.
    Now, we have tried converting the .shx font through a downloaded converter, and were unable to load the converted file into Autocadd without errors.
    In the end, we really do not want to lose the visual look of Monoarch, as our drawings have been using this as a standard for years, and most of our opporating systems are still using this .shtx font on current projects, on an older release of ACAD. So moving forward, we would like to make the total switch to TT Font now, and never have to look back (haha), and hope that drawings produced from both the current and older software have reasonably similar visual qualities.
    Any help and/or information would be much appreciated, thank you in advance!
    Cadfused
    Last edited by ablaydon; 2010-02-23 at 07:29 PM. Reason: .shx fonts not .shtx (typo)
    Earth
    9,631
    Default Re: Converting .shtx fonts to TrueType for 2010 ACAD and Revit
    These guys might be able to help
    http://www.tcfonts.com/
    R.K. McSwain | CAD Panacea |
    2005-09
    82
    Quote Originally Posted by ablaydon View Post
    FYI
    AutoCAD-Architecture definitely recognizes SHX fonts still - I don't have a working copy of plain vanilla acad to confirm that they didn't take that function out, but I would be very surprised.
    Revit Architecture 2010 on my machine is not recognizing SHX, but it appears to be happy with TTF and OTF, which is great, since the Desktop Publishing workld seems to be moving away from TTF in favor of OTF.
    0,0,0 The Origin
    8,569
    Quote Originally Posted by c.prettyman View Post
    FYI
    Vanilla 2010 certainly does support shx fonts.
    John B
    2010-02
    11
    Thank you guys!
    Hmm... ok, I guess we will try a different .Shx file then... I will have to work with my IT guru...
    Revit 2010 still leaves us then with the issue, as of right now, half of our pages are in revit, and half will be produced in ACAD... back to the conversion train...
    It's just so much easier to continue through with monoarch in some form as management in the office already is used to seeing that, and it just makes things much easier if we do not change font styles.
    2005-06
    in the upper right corner
    3,155
    Thumbs up Re: Converting .shtx fonts to TrueType for 2010 ACAD and Revit
    Thank you guys!
    If your company plans on continuing to operate this way in the foreseeable future, you may want to just set up our AutoCAD standards to use "TTF" instead of "SHX", that way they will at least match the REVIT work.
    Just a suggestion.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    Cairo - no, not Illinois
    4,726
    I would be leery of keeping going into the future with an older, non-typical font, whether it's custom or just no longer being shipped with the product. Older fonts are not likely to be unicode compliant, and will cause compatibility problems moving forward.
    You're going to have to bite the bullet and change at some point, so it's going to be cheaper to do it now in parallel with the revit deployment, than later after things are half and half all over.
    2010-02
    11
    Thanks everyone... we ended up finding a TT Font that is similar enough that it can fool most... The only thing we need to do now is make it the standard in ACAD 2010 and we're rolling...
    4,726
    To satisfy my inveterate curiosity,, which TTF did you elect to go with?
    2010-02
    11
    One called Architxt_Narrow.TTF
    It is incredibly similar to our old monoarch.txt With the exception of a little tick at the top of the numeral one, and the capitol i's having the top and bottom strokes, but these were deamed to be acceptable when the rest of the font was so close.
  1. Truetype fonts - printable samples for comparison
    By bb1 in forum Revit Architecture - General
    Last Post: 2011-09-16, 03:18 AM
  2. TrueType Fonts issue
    By lenagagnon in forum AutoCAD General
    Last Post: 2008-11-11, 05:29 AM
  3. Replies: 5
    Last Post: 2007-03-16, 12:02 PM
  4. TrueType or outline fonts vs. shx
    By SCROSLEY in forum CAD Standards
    Last Post: 2005-04-06, 08:01 PM
  5. Converting Adobe Fonts to use in Revit
    By Duffy in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-12-07, 11:24 PM
