How do I select non-continguous sheets in pn to print? It will only let me select 2 non-contiguous, then if I select a third sheet, it deselects the first one.
thank you.
acad architecture 2009
thank you.
Thank you, Dzatto.
Let me clarify. When I hold down the CTRL key to select sheets in project navigator, it will let me select two sheets, but when I select a third it will deselect one of the previously selected sheets. (ACA 2009.)
Any ideas on how to fix? FYI we no longer have IT support.
That's wierd. It works for me. I hold CTRL and can choose whatever sheets I want, as many as I want. I don't know why it's not working for you.
Test it in Windows Explorer and see if it works. It may be a windows thing and not a CAD thing.
Thanks - Yes, it works in Windows Explorer. It has worked in the past in PN too. Maybe it is related to the way AutoCAD crashes about 6 times a day.
Thank you. I'll try that after I talk to the cad manager.
