Thread: HP48 Calculator Replacement Needed
    2008-06
    56
    Default HP48 Calculator Replacement Needed
    We've got HP 48 graphing calculators, and using them as data collectors for a Leica Total Station.
    They're starting to break down and we need a replacement.
    Not making the 48 any longer, are there other graphing calculators that will work as a data collector? Obviously, we'd like something compatible with the survey cards that we already have, but if those must be replaced as well...
    Any suggestions?
    Dave
    9,805
    Default Re: HP48 Calculator Replacement Needed
  1. Replies: 0
    Last Post: 2014-11-05, 10:24 PM
  2. calculator
    By kornackiph in forum Revit Structure - Wish List
    Last Post: 2007-09-17, 11:05 PM
  3. SSM tag replacement
    By jamie.casile80054 in forum AutoCAD Sheet Set Manager
    Last Post: 2005-10-01, 12:03 AM
  4. replacement
    By jiaoyanbing in forum Revit Architecture - General
    Last Post: 2005-03-18, 05:47 PM
