Thread: How to change the copy command from "CO" to "CC"
    2009-11
    6
    Default How to change the copy command from "CO" to "CC"
    I'm having trouble finding a way to change the copy command from "CO" to "CC" in AutoCAD 2008.
    Any tips?
    Thanks!
    2000-01
    Seattle WA USA
    5,859
    Default Re: How to change the copy command from "CO" to "CC"
    Try AliasEdit in Express Tools, if you have them installed.
    If not, locate the Acad.pgp and add the following to the very bottom of the file (where user edits are to be located).
    CC, *COPY
    You could even change it so C is Copy and CR is Circle!
    C, *COPY
    CR, *CIRCLE
    There is no need to edit the default definitions. The last definition wins, which is why user edits belong at the bottom of the Acad.pgp file.
    P.S. Command: (findfile "acad.pgp")
    This will tell you where your Acad.pgp is located if you do not have AliasEdit.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-11
    6
    Thanks! I had heard about changing the acad.pgp file but couldn't find it on my 64 bit machine. The (findfile "acad.pgp") command worked great.
  1. 2014: Can't change parameter from "Instance" to "Type" in template family
    By Pavlin in forum Revit MEP - Families
    Last Post: 2014-02-11, 11:52 AM
  2. Replies: 8
    Last Post: 2012-08-18, 01:31 AM
  3. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 04:21 AM
  5. Replies: 3
    Last Post: 2006-03-23, 10:25 PM
