Thread: Parallel Walls
    I could stop if I wanted to roy.70844's Avatar
    2004-06
    South Wales UK
    278
    Default Parallel Walls
    Hello everybody,
    I am pretty sure that a new feature of Revit 6.1was that if two walls were parallel and the distance between them was less than 150mm then an door/window placed in one would pierce both walls. Does this sound familiar 'cos I can't get it to work!!!
    Roy
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: Parallel Walls
    Think you need to use the 'join geometry' tool on them first.
    2004-06
    South Wales UK
    278
    Thanks Peter, that works great.
    Roy
  1. 2013: Joining parallel stacked walls
    By tw.aia387041 in forum Revit - Platform
    Last Post: 2012-11-14, 04:40 PM
  2. Parallel Walls Joining Badly
    By gtarch in forum Revit Architecture - General
    Last Post: 2011-04-27, 08:42 PM
  3. Replies: 0
    Last Post: 2009-01-31, 03:55 PM
  4. Non-Parallel Walls
    By Wil W in forum Revit Architecture - General
    Last Post: 2007-10-19, 12:11 AM
  5. making a 'non-parallel to ucs' object parallel
    By KevinBarnett in forum VBA/COM Interop
    Last Post: 2004-11-12, 01:21 PM
