Thread: Protecting Blocks
    2010-03
    Default Protecting Blocks
    Hey,
    I am looking to do a series of blocks for in house use but have been asked if i can apply some kind of watermark so we can put them on our website so others can use but keep our company name on them for promotion purposes.
    Obviosuly there is no point just creating the block with text on as explode is an easy way around this. Is there any way i can make a block non explodable for outside use? They are dynamic so should never need to be exploded.
    So just wondering how can i lock a block as such so it can't be exploded!
    Cheers,
    Dan
    2000-01
    Seattle WA USA
    5,859
    Default Re: Protecting Blocks
    You might give CADLock a try.
    Otherwise, there is not much you can do. You can set the block properties to prevent exploding, but nothing prevent others from doing the same to enable it. Also, preventing exploding the block does nothing to prevent someone from simply edting the block definition.
    Face it, the effort to protect it isn't worth it. Even if you do protect it, someone can reverse engineer it rather easily.
    R. Robert Bell
    Design Technology Manager
    Stantec
    Cairo - no, not Illinois
    5,069
    If it's for promotional purposes, then is there a convenient spot on the object that you can put the company name as a label? I've used various vendor supplied equipment blocks where that was done, certainly it's still possible to bleep out the name one way or another, but it served the purpose of advertising the product.
    If you're interested more in tracking usage, then it would be possible to add a text string as xdata to each element in the block,,,,, IIRC a previous employer used a custom shx file for their standard font - basically a tweaked simplex, with one of the high numbered ascii characters being their name.
  1. Protecting DWG files
    By mark.perrins in forum CAD Management - General
    Last Post: 2011-01-28, 12:14 AM
  2. Protecting Revit Families?
    By Jim Merritt in forum Revit Structure - Families
    Last Post: 2009-12-24, 12:25 AM
  3. Protecting Fields
    By jnoon in forum Dynamic Blocks - Technical
    Last Post: 2009-06-11, 09:22 PM
  4. Protecting files with a password?
    By SaraS in forum AutoCAD LT - General
    Last Post: 2007-03-25, 07:05 PM
  5. protecting vba
    By inner69923 in forum VBA/COM Interop
    Last Post: 2004-06-16, 08:28 AM
