Thread: Global coordinate system batch conversion
    Battle Mountain, Nevada
    82
    Default Global coordinate system batch conversion
    Is it possible in Map '10 to do a batch conversion of the coordinate system in a series of dwgs without needing to open them one at a time? One of my colleagues needs to convert a large number from State Plane to mine grid.
    Thanks,
    Ray
    R. G. "Ray" Thompson
    Graphics Tech
    Newmont Mining Corporation
    P.O. Box 1657
    Battle Mountain, NV 89820
    Ph: 775.635.4981
    Fx: 775.635.6627
    TN/KY Area
    1,640
    Default Re: Global coordinate system batch conversion
    Not very easy. You would need to create a script to open a blank file, attach a dwg then query in all, detach the queried dwg, save. Do the dwgs have a cs code assigned to them or were they just drawn in the georeference location?
    82
    Quote Originally Posted by Jmurphy View Post
    I'm not sure. He just asked if there were some way to convert more than one dwg at a time. I wll have to ask him the next time we talk.
    I hoped Map would have some easy way of doing it, but was not overly optimistic.
    Thanks for the input,
    Graphics Tech
    P.O. Box 1657
    Ph: 775.635.4981
    Fx: 775.635.6627
  1. 2013: 3D Cartesian Coordinate System: Batch input with Work Point Labels
    By rusa67 in forum Inventor - General
    Last Post: 2013-02-04, 04:44 PM
  2. ESRI .prj conversion to coordinate system
    By caduser051574 in forum AutoCAD Map 3D - General
    Last Post: 2012-09-07, 06:02 AM
  3. Coordinate conversion in C3D
    By jtgb in forum AutoCAD Civil 3D - General
    Last Post: 2007-09-16, 03:53 AM
  4. VBA: Assign Global Coordinate System
    By kevin.bell81772 in forum AutoCAD Map 3D - General
    Last Post: 2005-01-28, 01:59 PM
