Thread: Switching between Tool Palettes cause view option on Palettes to reset
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Switching between Tool Palettes cause view option on Palettes to reset
    we are a large firm and have different pallets setup for different disciplines and clients.
    We switch from pallet to pallet via a palette switcher that has been created for us. The question I have is every time I switch pallets I loose my view options. They go back to large icons with text.
    Is there a variable so that I can change it to default to a different view option upon loading?
    The Silent Type CADMama's Avatar
    2016-01
    Where reference planes have Defines Origin checked
    1,040
    Default Re: Switching between Tool Palettes cause view option on Palettes to reset
    Anyone ever find an answer to this one? Someone just called me with this very question.
    CADMama
    2006-01
    Land of chocolate
    228
    ah - the view settings are saved in the autocad profile in ac2005 - when swithing toolpalettes with toolpalettepath, the viewsettings are reset.
    In ac 2005 the toolpalettepath command is use in macro's to handle palette groups - because you can't export those in ac2005.
    fromoff 2006 you can, and therefore don't need to use the toolpalettepath anymore
  1. CP223-1: Trick Up Your Tool Palettes: How to Make Your Tool Palettes Do Even More!
    Last Post: 2015-08-07, 05:17 PM
  2. No export option for tool palettes
    By donchak in forum AutoCAD Customization
    Last Post: 2008-06-27, 07:43 PM
  3. Saving the Tool Palettes View Options
    By Masroor Javid in forum ACA General
    Last Post: 2008-04-16, 01:37 PM
  4. Replies: 6
    Last Post: 2007-02-20, 01:29 PM
  5. Automatically change Tool Palettes view option
    By HookOn3D in forum AutoLISP
    Last Post: 2006-10-20, 04:14 PM
