Thread: Copy/monitoring Framing
    2009-08
    105
    Default Copy/monitoring Framing
    I am using both Revit Architecture 2010 and revit Structure 2010, there is no problem with the monitoring of Grids, Levels, Column, Walls, and Slabs. but the only thing that bothers me was when I created Framing in Revit Architecture and I want that not to create again in revit Structure because it is time consuming .
    Anyone could suggest me what is the best remedy to perfectly export Framing going to revit structure from Architecture. I have done Structural framing in Revit Architecture thinking it is posible to do because what is the sense of Placing Framing Panel to the Home tab of Revit Architecture if it is not be exported to Revit Structure or vice versa.
    thanks
    2007-03
    Melbourne, Australia
    278
    Default Re: Copy/monitoring Framing
    Not sure why you would want two models to have copies of the same framing information? Cant you just work with the framing being linked from the structural model?
    But to achieve what you are after,your best option is to unload the architectural model from the structural model if linked
    Open the Arch model, copy to clipboard the structural framing, then go back to the structural model and paste
  1. 2015: Which model am I copy/monitoring from?
    By MooksBK in forum Revit Architecture - General
    Last Post: 2014-12-16, 07:20 PM
  2. 2014: Copy/Monitoring Structure
    By rdooley944157 in forum Revit Structure - General
    Last Post: 2013-12-18, 12:04 PM
  3. 2014: Copy/Monitoring Structure
    Last Post: 2013-09-06, 01:59 PM
  4. Replies: 1
    Last Post: 2011-11-16, 12:41 PM
  5. Floor Drains-Copy Monitoring?
    By sfraney in forum Revit Architecture - General
    Last Post: 2008-06-23, 07:03 PM
