Thread: sky blocks
    2010-02
    Default sky blocks
    Hi,
    Does anyone know how you can insert a sky block into a drawing and get it to crop around the building? I managed to do it by exploding the block and then using the Power Fill Tool, but the process was a bit messy and time consuming. Is there a more simple solution?
    Thanks in advance for your help,
    Lesley
    100 Club vsheehan's Avatar
    2005-05
    Richmond, Va
    162
    Default Re: sky blocks
    Have you tried to right click on the sky block and send it to the back?
    Vince
    Civil 3D 2018 64bit, 3D Studio Max 2018 64bit
    Windows 10 64bit
    990x i7 w/24Gigs of DDR3 Ram
    NVIDIA Quadro K2200 Graphics Card
    http://polyin3d.blogspot.com/
    https://www.linkedin.com/in/vsheehan/
    2010-01
    4
    Quote Originally Posted by vsheehan View Post
    you would then need to create a new fill of white, or whatever your background is, between the sky and the cad. Unfortunately I dont think there is easy solution to this...yet!
  1. Change defaults for adding blocks to Multi-View Blocks
    By Ed Jobe in forum ACA Wish List
    Last Post: 2011-07-25, 05:11 PM
  2. Base points in Blocks not behaving when I make Blocks use annotative scale
    By dood in forum AutoCAD Land Desktop - General
    Last Post: 2007-06-10, 04:51 PM
  3. Replies: 1
    Last Post: 2007-01-05, 01:38 AM
  4. Replies: 3
    Last Post: 2006-09-12, 11:17 AM
