Thread: Batch Plot DWFs create empty DWFs
    2002-12
    2
    Default Batch Plot DWFs create empty DWFs
    Bonjour!
    I'm using a script with scriptpro to generate DWF files in batch but I have a problem. When I open these DWF files, I see nothing. I have to do a zoom extend to view the drawing correctly in the DWF viewer. When I generate the file manually, I don't have this problem.
    In the script file, I import a page setup and then I plot the drawing in DWF file.
    Thanks
    2015-12
    Arizona
    2,478
    Default Re: Batch Plot DWFs create empty DWFs
    Is the Page SEtup that you are importing
    established as plotting the LAYOUT, or is
    it extents, window or other?
    2002-12
    2
    I use 'Extents' and the driver is 'DWF Classic'
    2015-12
    Arizona
    2,478
    Quote Originally Posted by jlandreville
    This then is the 'problem' change your process to be LAYOUT
    not extents and you wont have to zoome extents to see the
    plotted (DWF) output.
    13,656
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS32983 - Use Batch Plot utility to automate creation of DWF™ files
    If you are using AutoCAD 2004 or above take a look at the PUBLISH command
    A search within the Forums should turn-up some useful information on this subject -
    Search Forums
    Have a good one, Mike
  1. DWFs look dark
    By kyle.sutherland in forum Design Review - General
    Last Post: 2010-02-08, 10:03 PM
  2. batch plot dwfs
    By sblumenbaum in forum Revit - API
    Last Post: 2006-09-20, 07:38 PM
  3. Cannot create seperate sheet dwfs with batch plot?
    By david.kingham in forum Revit Architecture - General
    Last Post: 2005-03-14, 07:25 PM
  4. 3D DWFs
    By Scott D Davis in forum Revit Architecture - General
    Last Post: 2004-09-08, 10:57 PM
