Thread: Tolerances in the Parameter Table
    2010-04
    Default Tolerances in the Parameter Table
    Is there any way possible that I can assign a tolerance in the parameter table in Inventor Pro 2010 (either by importing an excel file, or just typing it in)? I need to create a bunch iFeatures of high tolerance grooves and cannot possibly manually enter the tolerances for each size (there are thousands). I know the parameter table lets you choose how the model is displayed, but I cannot find a way to have the parameter table define the actual tolerance.
    I have been told several times that this is not possible. However, I have personally seen a spreadsheet driven drawing assign tolerances to a dwg. I asked the designer how he made it work and he did not know. Whoever set it up was no longer with the company. I suspect maybe that the model didn't actually have the tolerances assigned, maybe it was just the dimension in the dwg file. I have been unable to figure out a way to do either though.
    Any help will be greatly appreciated!
    2010-03
    Default Re: Tolerances in the Parameter Table
    If you right click on the equation(or click the arrow to the right of the cell) you can add a tolerance to the parameter manually.
    I know the link button will link the parameters to an excel file but I do not know how this works.
  1. 2013: LOOKUP TABLE PARAMETER UNITS
    By blanchardpaul in forum Revit MEP - Families
    Last Post: 2013-07-22, 04:30 PM
  2. Lookup Table Parameter Value Types and Uses
    By tony.jay.tutay224747 in forum Revit MEP - Families
    Last Post: 2010-07-12, 06:42 PM
  3. Tolerances Controlled by Holes Tolerances.xls
    Last Post: 2006-05-06, 04:24 AM
  4. trouble with adding a parameter to an array of chairs around a table
    By cparsons in forum Revit Architecture - Families
    Last Post: 2006-02-17, 10:18 PM
  5. Passing Table name as a parameter
    By lambertm in forum VBA/COM Interop
    Last Post: 2005-03-23, 03:20 PM
