Results 1 to 10 of 11
Thread: Sheet Set Total Field
    ACAD Wish List Administration
    2005-06
    1,920
    Default Sheet Set Total Field
    Summary: A field for the total number of sheets in a sheet set
    Description: FIELD EDITOR to have a SETSETSHEETTOTAL option for a total count of sheets in a sheet set. We could then use SHEETSETNUMBER and this new field to make a "Sheet # of (total) #" block more easily.
    How Used: Another universally used field on drawings
    Feature Affinity: Fields
    Submitted By: BILL PATTEN on February 5, 2010
    2001-02
    Charlotte
    89
    Default Re: Sheet Set Total Field
    Also, be able to control whether a sheet is to be included in the set or not. For example, we may have coordination, takeoff, presentation etc. sheets that aren't part of the cd set. So you need control to be able to not include in drawing index similar to the way you can check "include for publish". Two more options that would be similar to "include for publish" 1. Include in drawing index 2. Include in sheet total
    Earth
    9,803
    We have had this for years. Just create a custom 'sheet set' property, name it what you want, then reference it in your field.
    R.K. McSwain | CAD Panacea |
    2001-02
    Charlotte
    89
    Are you referring to the total number of sheets? If so, are you saying you type in the total number of sheets into the field so it will read in the field on the titleblock.
    Earth
    9,803
    Quote Originally Posted by bb View Post
    Yes.
    No, we create a custom property in the sheet set, then reference this custom property in a field.
    2001-02
    Charlotte
    89
    Is it automated or do you need to calculate the number of sheets and type that into the custom property?
    All AUGI, all the time Liamnacuac's Avatar
    2016-01
    Earth
    508
    The way I've been doing it is create the variable, and as the number changes, I have to update this variable. My wish is thatthis part is automated. I'll bet it wouldn't take much code to add a pick box that could be assigned to a particular plot set, such as Permit, Bid, CD, etc.....
    Earth
    9,803
    OOTB - you would have to manually update the sheet total.
    Ours is automated though. We wrote some code to renumber the sheets from 1 to ?? and then update the sheet total custom property.
    If Autodesk implemented an automatic count, it probably wouldn't work for us since we have special cases. For example on many sets, we have two cover sheets that count as one sheet.
    2001-02
    Charlotte
    89
    I assume it numbers based on the order or your set. Are you able to exclude sheets? Is it something that can be coded in autocad through diesel or something else or did you need to develop it outside of cad with something like .net? I've been wanting to figure out a way to automate it but haven't had any luck. If it is something that can be done without an outside application I may be able to tackle it. It may be over my head though.
    Earth
    9,803
    It's currently written in VBA (yes, I know it's dying...) so we'll have to port it over to .NET or something else when VBA is no longer available.
  1. Replies: 1
    Last Post: 2013-11-25, 11:39 PM
  2. Replies: 0
    Last Post: 2013-11-25, 05:43 PM
  3. Sheet Total Parameter for Use in Titleblocks
    Last Post: 2013-10-25, 03:09 PM
  4. Automatically Generate Total Sheet and Total Subset Sheet Numbers
    Last Post: 2009-07-07, 06:02 PM
  5. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
