How does one copy from an existing layer to a new layer, without changing the existing layer.
In AC2008 you can use the copytolayer command.
If earlier ACad, Copy @0. Then type PSELECT and P for previous. Then change the entities to the new layer. PickFirst needs to be set to 1.
Another way is to use "ctrl-c" or to right-click, pick "copy" or "copy with base point", then chose the objects. Then go to the target layer with layer properties manager and paste using "ctrl-v" or right-click and choose one of the 3 "paste" options.
OOps, you're right. It doesn't actually change the layers of the objects. Sorry for the confusion.
Only for one object though! If you want to copy several objects at once to a new layer, then bruce's idea is the closest work-around (although it actually "moves" the originals to the new layer and leaves the copies on the old layer).
Unfortunately ACad does not have a multiple-last selection set. It's been in the wish list a few years ago. Or you could use my addon for the "Result" selection set ... see these threads:
