Andrew.Shield1
Have done the quotes around the entire string and it fails.
stops at a layer with a space in it - space being enter and asks for an option.
I'm not sure what the problem is. I just tested it again and it works fine.
Here is the command line output:
PHP Code:
Command: script
Command: ._layer
Current layer: "0"
Enter an option
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/MATerial/Plot/Freeze/Thaw/LOck
/Unlock/stAte/Description/rEconcile]: _F
Enter name list of layer(s) to freeze or <select objects>: "layer with
spaces,another layer name"
Enter an option
Command:
And of course it works fine entering this at the command line manually also.
