Thread: FDO provider for Oracle
    2009-02
    Unhappy FDO provider for Oracle
    Hi,
    I have a problem to connect AutoCAD MAP2010 FDO provider for Oracle.
    I installed Oracle 10.2g XE.
    The message when i try to connect is:
    The specified credentials is not valid or the provider is unable to establish a connection.
    i´m using Windows Vista, AutoCAD MAP2010 SP1 , and Oracle 10.2g XE
    somebody nows the solution ?
    TN/KY Area
    1,640
    Default Re: FDO provider for Oracle
    The provider for Oracle in Map3D is for the enterprize version not the XE. You need to use the provider from SL-King http://www.sl-king.com/fdooracle/fdooracle.html.
  1. FDO Provider Issues
    By Joey.Diehl in forum AutoCAD Map 3D - General
    Last Post: 2010-05-10, 04:03 PM
  2. sqlite 3.5.0.0 provider
    By john.bendix in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-01-03, 10:38 PM
  3. ESRI 9.3 FDO provider for 2008
    By Ed Jobe in forum AutoCAD Map 3D - General
    Last Post: 2009-08-13, 05:53 PM
  4. Revit Content Provider
    By jdbejk in forum Revit MEP - Families
    Last Post: 2008-06-13, 02:08 PM
