Results 1 to 8 of 8
Thread: Shipping Container
    2010-02
    Default Shipping Container
    Hello all,
    My name is Alexander and I work for a company called Stack Design Build. We do a lot of work with shipping container projects; Check them out here: and/or , or check out our blog at .
    We need a parametric shipping container family to operate in RevIt. It must have functionality in width and height. It also needs walls and ceilings to be able to be turned on/off. Does anyone know someone who can build this? Or does anyone have something like this that you are willing to send me? Any help would be greatly appreciated, thank you.
    2009-06
    39
    Default Re: Shipping Container
    I just designed a new office for my firm. we're moving into 9 cotnainers at the end of may cuz we cant afford to pay rent anymore. In order to draw our new office in revit, I modeled a frame family, a door family and a wall void family. I found that this was the best method for assembling containers. although I made the mistake of using the wall voids individually to emulate the panel corrugations. in retrospect it would be smarter to array the voids within the family itself. not in the project. I assembled a container in the project and then made it into a model group so that the containers could be easily moved / duplicated. hope this helps, good luck
    2011-06
    2
    Quote Originally Posted by courtlandtgross View Post
    I tried to download your files w/o luck. For some reason its format goes from revit to a php.
    2004-06
    Memphis TN area
    7,048
    You probably need to join AUGI to be able to download files.
    I personally wouldn't model the container corrugations at all unless you need it for a REALLY high-end rendering, and even then I still might just do it as a material with a bump map. I would just model the full depth of the panel as a wall and use a model pattern to represent the corrugations in elevation and 3D.
    2011-06
    2
    Quote Originally Posted by patricks View Post
    well, it's funny I already joined the forum and still shows my presence as a guess. I was able to download the file [presents it self as a .rfa but when I look for it in my computer it shows as a php file.
    Yuri
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Did you activate your membership from the e-mail that was sent to you?
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    2007-05
    SF CA USA
    314
    The corrugation might be nice to have modeled for callout/details. Perhaps a line-based family of a standard corrugation section (vertical rib) with a height variable as a type, set in a standard repeating increment? Would need to deal with openings with voids, however...
    2020-10
    Wow, what a design. As a person who works in a shipping company, I just found out that shipping containers can be used for useful things when they are no longer used.
  1. Projet maison container à Toulouse
    By pascalcardop in forum Revit - Gallery
    Last Post: 2021-03-07, 10:24 AM
  2. Calculate the Volume of a Container
    Last Post: 2013-02-20, 09:56 AM
  3. Stress analyse, subsea container
    By wtr101391 in forum Inventor - General
    Last Post: 2012-05-04, 07:21 AM
  4. Cargo container CAD drawing
    By seelan in forum AutoCAD General
    Last Post: 2010-10-26, 06:57 PM
