Thread: Construction documentation and overall detailing tolerances
    2007-04
    21
    Default Construction documentation and overall detailing tolerances
    Hello,
    I wanted to get some opinions on what people are doing for best practices in regards to CD's and dimensioning details and Revit architecture 2010.
    Just as a 2x4 is not really 2"x4" there are dimension tolerances that get screwy. Can anyone tell me what they do and what level of detail they show in their CD package?
    Now that we are entering into the CD phase of the job we are starting to lock in dimensions. The questions is that while doing external dimensions you don’t want to show the fine tolerance on the dimensions such as an external wall being 7-5/8” it would come across as 8”. where does that 3/8" go? What is the standard way of addressing these issues In the drawings and where do the dimensions get added and how do we control what is being shown.
    Thanks in advance.
    2005-12
    566
    Default Re: Construction documentation and overall detailing tolerances
    There are a lot of answers depending on your intention. People doing CNC work have tolerances in the thousandths of the inch. I like to build to within a 1/16". However, my wall thicknesses are always the accurate wall thickness of the assembly, so that if a material has a stated industry thickness of 7/16" inch, I don't round that number up or down. Likewise with 3/32" materials, I would accept a dimension with 1/32" precision. There are time when this may seem silly, like when two walls are to be separated by a 20-foot gap. We all know that most of the time dimensioning a 20-foot clear dimension to the 1/32" seems weird. However, I would accept that strangeness over intentionally losing accuracy for the sake of producing a round number dimension.
    2004-06
    Memphis TN area
    7,048
    We model with real dimension thicknesses of building materials, and dimension to the face of core (stud or block) for exterior walls, to the centerline of interior stud walls, and to one side of interior block walls. This almost always eliminates all fractions on my floor plans, while still maintaining true thicknesses of elements.
    One of the few exceptions is when an interior wall needs to align to the interior side of an exterior wall, such as with a corridor going to an recessed exterior exit door. Then there will usually be some fractional dimensions. But for us the exterior wall core face location usually takes preference (no fractional dimensions) and the interior wall falls wherever it falls to align with the inside face of that exterior wall.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Construction documentation and overall detailing tolerances
    An important best practice for Revit ( or any cad program, as well ) :
    Set units tolerance to 1/256" at the onset of the project, BEFORE modeling anything.
    Then place model components to even increments of feet, inches, and 1/8" fractions.
    Now, when the Structural engineer gets the Arch. model and links it, and places his dimensions, with his tolerance also at 1/256", you will not get the imfamous
    12' - 7 29/128" odd fractions showing up everywhere.
    Lessons learned long ago, the hard way!
    cheers......
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Quote Originally Posted by cliff collins View Post
    cheers......
    I remember my first drafting job in '97; it was a small SF residence. I received a call one day from the concrete contractor; asking me why my internal dimension strings were +/- 2" more than my overall dimension.
    Sloppy drafting? Maybe. But I remembered that when I started working on 200'+ wide buildings four years later.
  1. SE430-2: AutoCAD® Structural Detailing Steel Design and Documentation
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2019-10-19, 07:27 AM
  2. Replies: 0
    Last Post: 2013-07-14, 08:10 PM
  3. Replies: 0
    Last Post: 2012-01-24, 12:48 PM
  4. Detailing a family for Construction Doc's.
    Last Post: 2006-08-21, 02:42 PM
  5. Tolerances Controlled by Holes Tolerances.xls
    Last Post: 2006-05-06, 04:24 AM
