Thread: Curtainwall - Vertical mullions near corner cause horizontal mullions to not miter
    100 Club Eric Stewart's Avatar
    2003-09
    Raleigh, NC USA
    138
    Default Curtainwall - Vertical mullions near corner cause horizontal mullions to not miter
    Wow, long title and it pretty much says it all. However, I have a screenshot that better illustrates the problem.
    2003-09
    Raleigh, NC USA
    138
    Default Re: Curtainwall - Vertical mullions near corner cause horizontal mullions to not miter
    So..... No tricks to get the horizontal mullions to miter?
    2004-05
    Auckland, New Zealand
    341
    Eric
    You have to try all of the Combinations of the end conditions.
    2008-11
    73
    Is Corner 1 what you want it to look like? But Corner 2 is what Revit's giving you?
    Corner 2 has curtain grid lines near the corner, it's been my experience that there's a certain tolerance with the distance of a curtain grid to the edge and depth of mullion at that curtain grid. Simplified explanation - try moving the curtain grid you have near the corner a litter further away, at some point, you should see the horizontal mullions clean up.
    2003-09
    Raleigh, NC USA
    138
    Right, I need Corner 1 to clean up like Corner 2. However, I need the mullions near the corner as shown in Corner 2.
    Thanks anyway
  1. 2013: mullions in miter, conservatory
    By peter_smith376480 in forum Revit Architecture - Families
    Last Post: 2013-12-26, 03:50 PM
  2. Curtainwall Mullions
    By Arkman in forum Revit Architecture - General
    Last Post: 2011-08-03, 01:48 PM
  3. Miter Join Curtain Wall Mullions
    By cpiper in forum Revit Architecture - General
    Last Post: 2007-09-25, 08:48 PM
  4. Sloping select horizontal mullions in a curtainwall
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2007-03-08, 05:56 AM
  5. Curtainwall Mullions
    By RodneyLester in forum Revit Architecture - General
    Last Post: 2004-11-12, 12:55 AM
