Thread: Error Message - Can't create this kind of element in this view in the current mode.
    2009-06
    Stokesley, North Yorkshire. U.K
    11
    Unhappy Error Message - Can't create this kind of element in this view in the current mode.
    Hi, I am fairly new to Revit. However, when i'm trying to pull in a steel beam family from the project browser [in my main project model], I keep getting the error in the subject line above.
    Has anyone else seen this error and know what it is telling me?
    Do I need to switch a "mode" somewhere that I am not aware of?
    I am currently using Revit MEP 2010, all the other families are loading in without any errors.
    Any help would be appreciated.
    Regards
    Graham D
    2008-02
    Austin, TX
    210
    Default Re: Error Message - Can't create this kind of element in this view in the current mode.
    Quote Originally Posted by gdury View Post
    Regards
    Graham D
    I think that Revit MEP doesn't like it when you try and insert structural elements. I know I've had to change a structural truss from it's native category to "Generic Model" to be able to use it.
    2009-06
    11
    Aaron
    Thanks for your speedy reply, please could you clarify how i can change it from it's current category to "Generic Model" or have you tried it already to see if it loads/visable.
    Regards
    Graham D
    2008-02
    Austin, TX
    210
    Aaron
    Regards
    Graham D
    Sure, just open the family in Revit, and click on "Category and Parameters", and change it to something other than Structural, then re-save the family
    2009-06
    11
    Aaron
    Thanks for your reply. I'll try it out.
    Regards
    Graham D
  1. "Can't create this kind of element in this view in the current mode."
    By kmayhew936033 in forum Revit MEP - Families
    Last Post: 2015-06-28, 02:40 PM
  2. Can't create this kind of element in this view in the current mode.
    By huntbh in forum Revit Structure - General
    Last Post: 2010-07-27, 12:39 AM
  3. "Can't create this kind of element in this view in the current mode."
    By kmayhew936033 in forum Revit Architecture - Families
    Last Post: 2009-12-17, 10:20 PM
  4. you now own the element....error message
    By moliva in forum Revit MEP - General
    Last Post: 2009-08-05, 11:15 PM
  5. Element is too small error message?
    By tiffany.amorgan in forum Revit Structure - General
    Last Post: 2006-10-30, 09:02 PM
