Thread: ActiveX Error Help....?
    2015-09
    420
    Default ActiveX Error Help....?
    Hello AUGI Members,
    I am trying to use the MakeTable.lsp program which was a free download from the Cadalyst site. However, whenever I run the code I get the following Error Message:
    MAKETABLE Error: ActiveX Server returned an error: Parameter not optional....!
    Has anyone seen this error before....?? Any recommendations on how to eliminate the error message....??
    Any help will be appreciated...!
    Regards,
    Vince
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: ActiveX Error Help....?
    Have you debugged this program through the VLIDE?
    I could stop if I wanted to msretenovic's Avatar
    2002-02
    Galloway, Oh
    305
    Smile Re: ActiveX Error Help....?
    The error occurs on line 410. The variable colleft is nil - this value is required and must not be nil. It is set on line 375 ONLY if the variable txtstr contains the value "DESCRIPTION". You can modify this by doing the following (line numbers are for reference only):
    374 | (if    (= txtstr "DESCRIPTION")
    375 |   (setq colleft col)
    376 |   (setq colleft 0)
    377 | ) ;_ end of if
    The portion in red is the part I added.
    HTH,
    2015-09
    420
    Hi Michael,
    Thank you very much for you quick and accurate solution to my post. I inserted the line of code as you outlined and the routine created the table.
    However, I am experiencing another difficulty with the program. Instead of the Title of the table being displayed on the top line the routine places the following text "CALCULATED CABLE DISTANCE" on the top line. Is there a solution to this anomolie....??
    Once again thank you for your expert resolution to my first post.....!
    Regards,
    Vince
  1. Error loading Navis ActiveX Plugin on IE
    By potapczuk542577 in forum NavisWorks - General
    Last Post: 2012-06-19, 09:02 PM
  2. Replies: 1
    Last Post: 2012-04-10, 01:57 PM
  3. Run-time error '429' (ActiveX component can't create object)
    By Pwned555402908 in forum VBA/COM Interop
    Last Post: 2011-12-08, 10:05 PM
  4. ActiveX error
    By d_m_hopper in forum AutoLISP
    Last Post: 2010-08-05, 04:26 PM
  5. Replies: 4
    Last Post: 2004-07-24, 04:18 AM
