Ok, I'll be brief...
Background: Client has sent us a converted Microstaiton file with alignment control lines.
Goal: Connect all control lines to create connected polylines that can be used as construction lines for street lightinging. This is essential as we use them to divide / measure the poles and then break to create conduit segments.
Problem: Cannot join certain segments of polylines / arcs together. It just will not work. Most prevalent where a single arc segment meets a converted spline.
Troubleshooting already done:
- All lines are coplanar - no effect
- no fuzz difference / add / extend / both options - no effect, except if the fuzz goes above 0.5 with the jointype set to "add" it goes nutters and joins all lines in weird odd angles
- splines have been optimized with different value no effect
- have run 'FLATTEN' with no effect
- have weeded out the extra segments in the converted splines - no effect
- tried pasting objects into a new drawing - no effect
- tried blocking / inserting objects - no effect
- have tried some third party LISP routines for joining polylines - no effect
- used overkill with various tolerance settings - nothing...
- used join as well nada
- redrawing an arc still does not work, the only way I can get this to work is to delete the offending object and use blend to create the new object. Then pedit the new blend / spline into the other segments..
Any ideas I'm all ears. I have attached an example file. Its no biggie to redraw some of this, but there are 5 other drawings with changes coming, there is no time in the future to redraw this. I am thinking I am going to have to relent and just do it (or appoint someone else to grind it out). My opinion is Microstation and how it converts certain objects is the problem in the end.
Thanks in advance.
