Thread: attribute extraction for length width & thickness of parts
    2010-04
    2
    Default attribute extraction for length width & thickness of parts
    Hi,
    I am new to this forum and would love some help.
    I am trying to extract parts from my drawing to a spreadsheet
    The information i want is the part name, quantity, length, width and thickness.
    I have run the 'dataextraction' wizard and cannot work out how to get what i need
    If i turn the parts into blocks i am able to get x y z values but they result in zero?
    How can i get the desired numeric values?
    Also the parts will need to be stored as blocks as an assembly and used and stretched as desired.
    Is this possible?
    Any help would be greatly appreciated.
    Thanks
    2015-11
    Jo'burg SA
    4,512
    Default Re: attribute extraction for length width & thickness of parts
    Welcome to AUGI & congrats on your 1st post.
    Could you give some more info about how these "parts" are drawn? You mention an assembly ... does that mean there's several part-blocks nested into an assembly-block? Are these blocks dynamic? And which version of ACad are you using?
    Maybe the best way would be to attach a sample drawing to this thread.
    2009-04
    42
    For the part name you would have to open up block editor and add an attribute to the block. For width, length, and thickness I think you can get that from the property manager. There you should find the width, length, and thickness. If not you would have to create an attribute for all three conditions and enter your own values. This is just too much work and try to avoid.
    Also try checking all the options on data extraction so that you can see what kind of data it is extracting from the block to your schedule. This will give you a feel for what data it is extracting. Then you can go back and uncheck options for data that you don't want to show up. Hope this helps.
    2010-04
    2
    "Could you give some more info about how these "parts" are drawn? You mention an assembly ... does that mean there's several part-blocks nested into an assembly-block? Are these blocks dynamic? And which version of ACad are you using?"
    I am using autocad 2010, in reference to the assembly i did mean several blocks nested together to create one block.
    I have attached a sample of what i want extracted, this includes four parts nested into a block, i want to extract the length width and thickness from each individual part within this block.
    Is this possible?
  1. All Parts should report their dimensions (Width, Height, Thickness, Area, Volume etc.).
    Last Post: 2013-03-22, 10:09 PM
  2. Attribute Extraction... Help please.
    By Imkie in forum VBA/COM Interop
    Last Post: 2008-12-04, 10:01 PM
  3. Help with RO and Length and Width
    By crullier in forum Revit Architecture - Families
    Last Post: 2006-08-15, 04:06 AM
  4. Enter wall thickness and length, to create Object
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-03-21, 01:39 PM
