Paul, That's not a Bug! Its a feature!
As some of you, I have started working in the new RAC2011.
I was editing a group, and I connot find the old Edit group tab in the ribbon.
So, I opened RAC2010 and found out that the shortcut is FG, and that did the finish group command.
But the edit group tab still isn't showing.
Am I missing something?
Yes, cliff. I meant 2011. Just corrected the post :P
But about what I just wrote,do you see that tab?
Maybe Al should be the new mascott for the ribbon in Revit 2011? Everytime I report a ribbon bug, Al is stuck on the side of my building.
When editing a group in 2011 the defult is for the edit group ribbon pannel to be "torn off" of the Ribbon and placed in the upper left corner of the canvas. This can be dragged and positioned elsewhere on the screen. Perhaps it is opening off screen somewhere, or positioned where you are not seeing it?
Were experiencing a pretty big bug with content that has Instance yes/no parameters, which are driving formulas in the Family. Changing the value of the parameter in the project environment causes Revit to go wild, and you can no longer see your selection window. Sometimes clicking soemthing else or tabbing to another opened project alleviates the display issue, but it PUTS THE PARAMETER BACK to the other value.
Its very strange, but weve made the Factory aware. Will post updates as we get them. Unfortunately for us, that means a great deal of our library cannot be used, ergo we cannot upgrade right now.
EDIT: This only happens with using the Properties palette and then clicking back to the modeling window. if you use the apply button, it doesnt happen and Revit behaves as normal. Kudos to Robert Manna for the find.
