Results 1 to 10 of 13
Thread: Slide Library images not showing
    2008-10
    279
    Default Slide Library images not showing
    Hi all,
    Transfered a CUI from a 2007 machine to a new 2010 machine - everything has worked well apart from images/drawings in a slide library are not showing.
    Everything is looking in the right place and the custom menu 'Symbols' functions - just doesn't actually show the library files...
    Any idea's how to get this sorted?
    I'll try and attach an image to explain what is being seen.
    Any help appreciated : )
    2008-10
    279
    Default Re: Slide Library images not showing
    I found a discussion on the Autodesk website that suggests:
    "deleting the .mnr and letting it recompile?"
    What exactly is this .mnr and where to I find it?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,177
    Quote Originally Posted by jayc View Post
    In the same folder that your menu (CUI or CUIX) file is located.
    2008-10
    279
    Thanks Opie
    Have you seen this issue before?
    Everything looks just about fine - it's just the images that don't show up!
    2002-01
    jUSt Here (a lot)
    9,177
    I don't use the slide libraries.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    MNR file is a resource file containing all the images in a menu.
    Do you still have the slides (.SLD files)?
    2008-10
    279
    Hi Scott,
    Thanks for explaining what the .mnr is!
    The .sld files are stored on a network - all the machines are directed there to access the slide library.
    This has worked fine on the AutoCAD 2007 machine, but for some reason the images aren't showing up for the new 2010 one.
    Deleting the .mnr didn't work
    2008-01
    Columbia, Missouri
    15
    Hey jayc,
    In the CUI look for Legacy then look for Image Tile Menus. This is where you will need to put your image library.
    2015-11
    Edmonton, Alberta
    990
    Try adding the path to the slide files to your AutoCAD support path and renaming the existing .mnr file. AutoCAD should rebuild the tiles and create a new mnr file. This should load when your other users startup AutoCAD.
    Cairo - no, not Illinois
    5,070
    I might be wrong, but I don't believe that there's any connection between the mnr files and the slide libraries,, The slide.slb contains the images for the old style icon/slide menu
  1. 2012: AutoCAD Slide Library
    By rbhazie in forum AutoCAD General
    Last Post: 2015-12-07, 08:58 PM
  2. Slide Shows of Images and Drawing Images
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-01-25, 08:12 AM
  3. Slide Images
    By david.brissenden in forum AutoCAD Customization
    Last Post: 2008-08-23, 12:14 PM
  4. Update Slide Library
    Last Post: 2007-05-25, 05:03 PM
  5. How to bring in a Slide Library into AutoCAD 2006
    By lance_lie in forum AutoCAD Customization
    Last Post: 2007-01-22, 02:15 PM
