Anyone find out how to access these?
They are available for materials that you can specify an image. Click on the drop down arrow to the right of the image box.
Except it doesn't work...at least for tiles. OOPS - DOH AGAIN.
Can you be more specific? A quick test worked for me...
It does work! I was being "not so smart."...
However. On a 2' x 2' brick pattern (3 wide x 9 high - typical), the realistic view is very nice, but creates two-high stack pattern every 10 courses - the rendering is correct, though. So, that's just a little bug, as far as I can tell. No biggie.
Ok. Figured that out: Tile Count = 0 Per Row, 1 Per Column, Scale 20' Width, 4" Height. You have to make the width wider than the wall you're working on in the model.
Are you using the Tile procedural to do clapboards? Why not use one of the siding materials?
Yes. I was fooling around with it. In the past, I've found procedural materials (specifically Accurender nXt) to be better, because the lines are more realistic. When you look at a clapboard house, you see pretty clearly dark horizontal lines. When I tried those materials in previous versions of Revit MR, they were very, let's just say, anemic....
