When I label a sinle contour how do I designate which label style. I have two styles, one for existing majors and one for proposed majors.
You need to go into the Add Labels dialog box. That is the easiest way to change the current style.
you can go into your Settings Tab in your toolspace. Right click on Surface and select Edit Feature Settings. In here you can also set the default surface label style. It also very helpful to have your Add label dialog box up so you can switch your surface labels on the fly.
Tony
www.tonyscivil3dworld.blogspot.com
