View Poll Results: Should Titleblocks contain Generic Labels?
Voters
10. You may not vote on this poll
  • In Favor of a Generic Label
    5 50.00%
  • Not In Favor of a Generic Label
    0 0%
  • Don't Understand Why a Generic Label is Needed
    1 10.00%
  • This can already be accomplished!
    4 40.00%
Thread: Labels that Refer to Nothing
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Default Labels that Refer to Nothing
    My wish stems from the fact that I would like to put a text 'label' in a Titleblock Family that doesn't need to refer to a parameter (similar to attributes in blocks). I would like to create a label for it so that all of the formatting stays the same across all sheets. What I don't want is this information to be the same on every sheet. I want this to just be a generic label text box that holds no 'global' data. I cannot seem to figure out how to do this in the family editor. It seems that I need to create a shared parameter.
    Please let me know if I am missing something. I'm also including a poll.
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
    2003-04
    Chino, CA
    4,756
    Default Re: Labels that Refer to Nothing
    What you need is a Sheet "instance" parameter. I don't think its doable yet.
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    Quote Originally Posted by Scott Davis
    Drawing sheet parameters are doable. Use Settings | Project Parameters | Add.. and set check-mark for Drawing Sheets category. You also need to utilize shared parameter since you want appearance of your parameter to be controlled by a title block label.
    I think that should do the trick. Let us know if I misunderstood your intent and things are not working out.
    Leonid Raiz
    2003-04
    Chino, CA
    4,756
    Corrected by Leonid again! Which I really don't mind.... When I start knowing more about Revit than you Leonid, well....we'll have to talk!
    Scott D Davis
    Autodesk, Inc.
  1. 2013: refer to linked view - dimension+ text orientation
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2014-07-08, 05:01 AM
  2. How to I refer to a detail ?
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-01-16, 10:53 PM
  3. Does a drawing refer to an XREF
    Last Post: 2006-11-01, 09:05 PM
  4. Need help finding this font (refer to image)
    By ajtrahan in forum CAD Management - General
    Last Post: 2006-10-23, 08:46 PM
  5. Notes that refer to drawing number on sheet
    By Archman in forum Revit Architecture - General
    Last Post: 2005-07-30, 12:46 AM
