Thread: Dynamic Simulation - Inventor 2010
    2010-04
    10
    Default Dynamic Simulation - Inventor 2010
    I am trying to simulate a foot brake assembly which consists of several welded sub-assemblies. I have put several 3D contact joints so that it stops when hit by a stopper. I have a spring attachment with the lever and base plate. But when I apply the force on the lever, the lever passes through the base plate instead of stopping by the stopper. I have attached the assembly picture. Any ideas or examples similar to this ?
    Williamsport, PA
    641
    Default Re: Dynamic Simulation - Inventor 2010
    In that picture you are not in the Dynamic Simulation environment?
    In the assembly environment you could add Contact Sets.
    If you really intend to be in Dynamic Simulation as the title of your post then you should go to that environment and add a 2D Contact joint (don't need a 3D joint for this).
    Have you read this book http://vdssolutions.wordpress.com/
    Can you attach the assembly here?
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
  1. Replies: 0
    Last Post: 2015-08-07, 05:34 PM
  2. Trouble with Joints in Inventor Dynamic Simulation
    By p.r.greaves in forum Inventor - General
    Last Post: 2010-03-03, 03:48 PM
  3. Dynamic Simulation?
    By fujifilm3000 in forum Español - Inventor
    Last Post: 2009-11-05, 04:42 PM
  4. Autodesk Inventor Dynamic Simulation course
    By sunithbabu78 in forum ATP Course Wishlist
    Last Post: 2009-06-06, 05:15 PM
  5. Autodesk Inventor Professional 11 Dynamic simulation course
    By eshu_k in forum ATP Course Wishlist
    Last Post: 2009-06-05, 06:00 PM
