Results 1 to 8 of 8
Thread: attribute which is not assigned to block is not visible in xref
    2008-12
    5
    Unhappy attribute which is not assigned to block is not visible in xref
    Hello,
    Please help me as soon as possible.
    I have made one attribute with help of ATTDEF command. (Invisble is unchecked)
    I have not assigned it to block.
    When i xref this file to other file Attribute is not visible in that drawing. (All Layer is on and Unfreeze).
    please help me.
    2001-02
    Charlotte
    89
    Default Re: attribute which is not assigned to block is not visible in xref
    Did you make sure all layers were on and thawed?
    if so, check attdisp variable.
    Turlock, CA
    6,420
    Is the att in ms? You won't see it if you put it in ps.
    C:> ED WORKING....
    LinkedIn
    0,0,0 The Origin
    8,570
    Attributes only work when part of a block though they should be visible.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Go back to the original dwg, create a block from that attribute, and reload the XREF. You should then see it
    2005-06
    in the upper right corner
    3,508
    Yes as Scott mentioned above, you must make the "attribute defininitions" into a block.
    (I call them "raw attibutes" because they haven't been made into a block yet)
    Even though you can see the raw attributes in the xref file, they won't show up in the file you're bringing the xref into, until it's a block.
    2015-11
    Jo'burg SA
    4,512
    As mentioned AttDef's only become Attrbutes if used through blocks, not XRefs. So either place the AttDef inside a block in the xref, or in a Block in the current DWG.
    I'd also have liked the functionality you want, since this would make Title Blocks more easily used. You could attach the XRef inside the block in the current DWG to have it appear as if the Attributes are part of the XRef.
    2008-12
    5
    thank you all for your valuable answers..
    but i still not get how i want.
    if somebody know how or i wish it is cover in new version... then it will great..
  1. Replies: 13
    Last Post: 2012-09-18, 07:51 PM
  2. Block geometry is visible until block editor is opened.
    By 3ddraft in forum AutoCAD General
    Last Post: 2010-04-26, 11:47 AM
  3. Copy previous Block Attribute Value to next Block Attribute
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-02-27, 09:46 PM
  4. Objects not visible in drawing with xref.
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2007-06-07, 02:35 PM
  5. Block Attribute Manager Vs. Enhanced Attribute Editor
    By zoomharis in forum AutoCAD General
    Last Post: 2006-04-15, 11:53 AM
