Thread: Changing Annotative Scales
    2004-08
    69
    Default Changing Annotative Scales
    On leaders and dimensions if I select them then either on the pop-up panel or in the properties panel try to change the scale by picking (...) it just freezes autocad until I hit esc key. It never does open the add/remove scale window. It used to work just fine any ideas? Using 2009
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,486
    Default Re: Changing Annotative Scales
    Have you gone from dual monitors to a single monitor recently?
    2000-01
    Seattle WA USA
    5,859
    In other words, when the dialog should appear, try hitting Alt+Space, type M, then use the arrow keys to move the dialog box back onscreen. The location of the context menu from Alt+Space will give you a clue which arrow key you need to use, e.g. if the menu is on the right side of the monitor, use the left arrow key to move the dialog back onscreen.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2004-08
    69
    That was it Robert thanks for the help. That is a really needed pop-up!
    Active Member iamreavis's Avatar
    2007-07
    Charleston, SC
    50
    Thanks for the tip! Saved me a lot of frustration!
  1. Importing Annotative scales
    By mtc.139414 in forum AutoCAD Annotation
    Last Post: 2020-05-14, 02:10 AM
  2. 2012: Annotative Leader at Different Scales
    By Kennaway Elf in forum AutoCAD Annotation
    Last Post: 2013-07-21, 09:41 AM
  3. Default annotative scales
    By Pierre P in forum AutoCAD Annotation
    Last Post: 2012-03-12, 03:05 PM
  4. Categories for Annotative Scales
    Last Post: 2008-06-10, 05:06 PM
  5. Can't Change Annotative Scales
    By mockdeep in forum AutoCAD Annotation
    Last Post: 2008-02-14, 12:48 AM
