Thread: Fields in Attributes Problem -Data Extraction from Multiple Drawings
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    343
    Default Fields in Attributes Problem -Data Extraction from Multiple Drawings
    Hi all,
    I'm having a problem with Data Extraction in AutoCAD 2010 :
    I'm trying to create a drawing list using data extraction from the titleblocks within a group of drawings. This titleblock has a field for the drawing name, referencing the file name, and a field that references the latest revision info (which is inserted as a block).
    This worked beautifully in 2007. However in 2010 (and 2009), the list reverts all of the fields to whatever the value is in the first drawing on the list. So, my drawing list looks as if all the drawings are "#12345" and all of the revisions are "X".
    As I said, this worked fine in 2007. While I shouldn't have to, I can work around the drawing title by including the the actual file name, but the revision is a different matter.
    Has anyone figured out how to fix this?
    Thanks
    2007-07
    94
    Default Re: Fields in Attributes Problem -Data Extraction from Multiple Drawings
    Have you every try Sheetset list table? Basically if your titleblock field is linked to sheetset, you can extract the information and create drawing list from it.
    Massachusetts
    343
    Autodesk Subscription Center Support actually helped me out with this.
    Update 2 for 2010 addressed the issue, so I installed that and my problem was solved.
    If, for some reason, Update 2 is unavailable to anyone, changing the attribute to not be "constant" would, apparently, do the trick. For some unknown reason, that "constant" makes it constant across the whole group of drawings.
  1. 2015: AutoCAD LT Script that changes multiple attributes across multiple drawings
    By alecgburke704194 in forum AutoCAD LT - General
    Last Post: 2015-06-30, 12:21 PM
  2. Replies: 0
    Last Post: 2014-01-24, 07:48 PM
  3. data extraction from attributes
    By Maurice.148748 in forum AutoCAD General
    Last Post: 2010-11-05, 01:26 PM
  4. data extraction from multiple blocks
    By eric.kirk in forum AutoCAD Annotation
    Last Post: 2007-10-29, 05:58 PM
  5. Use Fields to extract data from other drawings
    Last Post: 2005-10-21, 02:00 PM
