Revit 2011 will not render ( fboxrender process will not start ) if Revit and 3dsMax Design
are open simultaneously.
Shutting down Max will allow Revit to render.
Has anyone else seen this, or confirm?
cheers........
cheers........
No, I can even have 3dsMaxDesign2011 and Revit 2011 rendering at the same time with no problems.
A problem I am seeing however is that cancelling a render in 3dsMD2011 hangs the PC needing Task Manager to get out of it.
...and another thing
I came across this which says us Metric types should change to Imperial units before exporting fbx for import to 3dsMD2011 because of difference in light emitter shape sizes.
http://tinyurl.com/2e4fltb
Thanks for those tips....
and that you can have R and M open simultaneously and render.
cheers
Not sure about that units thing from Autodesk...
Reading the FBX Help file it says that by default units are matched automatically... ?
So much to learn, so little...
