Thread: Square Foot Take-off using .dgn file
    2009-06
    Tucson, AZ
    58
    Default Square Foot Take-off using .dgn file
    I am trying to estimate the entire exterior square footage of a building to determine parameters for a building pressure test. My company is commissioning the building, and we have access to the designer's drawings, but they are .dgn. I use AutoCAD MEP 2010, and have Revit MEP 2009,10 & 11. Is there a way to import a .dgn into a Revit model, and once there, can Revit determine the square footage of all exterior surfaces of the building? I am very proficient in 2D AutoCAD, have limited and frustrated experience with Revit (but I keep trying), and know absolutely nothing about Bentley Microstation, except that it uses .dgn format, and that I can import the files with AutoCAD or Revit. I am having trouble with the importing into Revit 2010 right now, and the last error message said that I had an incompatible .dgn format. Before I go through the trouble of trying to get this to work, does anyone know if or how Revit can determine exterior square footage?
    My other option is to print .pdfs of the elevations, floor and roof plans, and get out a scale. I know it works, but it seems crude given how powerful modern software is.
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    756
    Default Re: Square Foot Take-off using .dgn file
  1. BO122-1: The Impossible 3-Million Square-Foot BIM Project
    By Autodesk University in forum Business Owner
    Last Post: 2014-11-17, 05:32 AM
  2. Lighting load calcs watts per square foot
    By terkoon in forum Revit MEP - General
    Last Post: 2010-06-22, 08:29 PM
  3. Square Foot Take-off using .dgn file
    By ckidd in forum QTO General
    Last Post: 2010-04-30, 07:12 PM
  4. How do I change the area calculation to be rounded to a square foot?
    By bradylady in forum AutoCAD Customization
    Last Post: 2007-11-20, 11:26 PM
  5. Square Foot Symbol in Unicodes
    By cadconcepts in forum AutoCAD General
    Last Post: 2007-11-05, 05:33 PM
