Thread: Wide Lines in Title Block Family does not show in model
    2009-06
    Cape Town, South Africa
    109
    Unhappy Wide Lines in Title Block Family does not show in model
    I have defined a title block with some of the frame lines as WIDE LINES.
    The Object Override Line Width in the family is set to the same value as in the main model, but all the title block lines print as thin lines from the model...
    WHY ??
    How can I fix it?
    2007-03
    147
    Default Re: Wide Lines in Title Block Family does not show in model
    Check your line weights for your wide lines.
    2003-04
    Chino, CA
    4,756
    in the project, check your Object Styles for title blocks. At one time the Wide and Thin pens were swtiched in the OOTB template.
  1. Replies: 4
    Last Post: 2013-09-07, 01:03 AM
  2. Need a Client Project Number field for title block that is project-wide
    Last Post: 2012-01-31, 02:28 PM
  3. Help Required - Wide Lines in Title Block
    By swmarais in forum Revit Structure - Families
    Last Post: 2010-05-07, 05:42 AM
  4. Want Revisions to not show on Title Block
    By wjspence in forum Revit Architecture - General
    Last Post: 2009-03-19, 08:49 PM
  5. Replies: 1
    Last Post: 2007-01-07, 10:08 AM
