Results 1 to 10 of 11
Thread: Material Length in material takeoff
    2004-01
    London
    115
    Default Material Length in material takeoff
    Hi All,
    I know this is known issue, but can anyone explain me why there is a Material Area field available and not a Material Length one?
    Moreover If I try to get a wall quantity takeoff I can't calculate totals for the wall length parameter....I know there is a workaround for this...but my question is again why we cant have a Material Length?
    Sometimes suppliers give me for some materials a cost per unit length (meters) so that would make sense. Is there a way to have a Material Length parameter in the quantity takeoff?
    2015-12
    Orlando, FL
    1,049
    Default Re: Material Length in material takeoff
    Maybe a Material:Length field is not available because materials don't have length. Elements such as walls have length, and are made of different materials, but Material:Length does not make sense. That's why the Length field is provided separately in both the regular schedule and the material takeoff schedule for wall objects, without any workaround needed.
    2015-12
    Orlando, FL
    1,049
    You can create a parameter that applies to walls, with something like "# of studs per linear meter of wall" (abbreviated, of course) for example. Maybe that is what you are looking for?
    2004-01
    London
    115
    Quote Originally Posted by info.234557 View Post
    Hi Alfredo,
    yes that is what I need but I'd like to be in the same schedule of material takeoff alongside material areas.
    Look at the picture. I found a workaround about creating a calculated value and using as formula the value of Length parameter (=Lunghezza). In this manner Revit can calculate totals. That's odd...why I cannot have Length totals straightforward?
    2006-01
    4,516
    Because not all Materials have a "Length." Youre saying you want the LENGTH of a wall that has GYP material in it. But that same GYP material may also be used in a ceiling, so what will it do for the Length field then?
    2004-01
    London
    115
    Quote Originally Posted by twiceroadsfool View Post
    that's the point...how can I set a material length to be scheduled? what materials have length in Revit?
    What if I have a particular material as wall sweep that for pratical issued is sold per unit length? Can I schedule this material within a wall material takeoff (alongside other material areas?)
    2006-01
    4,516
    Thats MY point. Then you dont want to schedule the MATERIAL, you want to schedule the OBJECT. Want the length of the Walls? make a wall schedule. Want the length of the wall sweep? Schedule wall sweeps.
    2015-12
    Orlando, FL
    1,049
    I am very new to this Augi forum. Let me ask this question. When I hit Reply, how do I reply to one of the messages in particular? or is my reply just to the whole thread?
    Anyway, my comment to the thread is: Materials don't have length. A wall has length, but how can a material have length? If your providers are giving you the price of their products by linear meter, what you need to do is to calculate how many linear meters of those products you need by each linear meter of your wall. That is something different. That can be achieved with parameters, applied to walls.
    In addition, can you please post a picture showing the properties of that parameter called Lunghezza (length) that you are using?
    Pittsburgh, PA USA
    1,906
    IF you hit quote, then it quotes the previous post you are trying to provide a more specific answer to. It will still appear to the entire thread. If you just hit reply, then it is a general addition to the thread (in effect).
    Good Luck!
    2015-12
    Orlando, FL
    1,049
    Quote Originally Posted by Scott Womack View Post
    Good Luck!
    Ah, ok, so this is a reply to your message, using the Quote button. Thanks!
  1. Material not showing up in Material Takeoff
    By pial01 in forum Revit Architecture - General
    Last Post: 2011-08-03, 03:44 PM
  2. Material Takeoff does not substract Painted Material
    By joel.196524 in forum Revit Architecture - General
    Last Post: 2009-07-30, 02:15 PM
  3. Material Takeoff for MEP
    By diesellam in forum Revit Architecture - General
    Last Post: 2009-05-08, 10:55 PM
  4. Total Length in Material Takeoff
    By roy.70844 in forum Revit Architecture - General
    Last Post: 2007-11-21, 04:35 PM
  5. Material sample in Material Takeoff
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2006-04-26, 09:46 PM
