Results 1 to 6 of 6
Thread: Problem with autosave
    2004-12
    3
    Angry Problem with autosave
    I'm running the LDD 2005 package with Map. I have been having a strange issue with my autosave, it turns itself off with no warning or reason. I think my video card (ATI) is causing my drawings to lock up which happens with no error message and sometimes after a crash my autosave will be set to zero. If I catch it, its no big deal but I have lost alot of work because this keeps happening and Autodesk has no solution nor does my reseller. So I send out a cry for help, has anyone any idea of what I can do to prevent these things from happening?
    P.S.-I primarily use the MAP portion of the software as I have little need for LDD.
    100 Club Phil Ferguson's Avatar
    2002-08
    Buckeye State
    137
    Default Re: Problem with autosave
    Try disabling the 'Power Play' option in the video adapter properties. This may be causing the problem.
    2004-12
    3
    I'll try that tahnx! GO BUCKS!!
    Active Member amy.stuart's Avatar
    2004-05
    nebraska
    88
    okay, has this worked? I have 3 users that have had their auto-save randomly shut-off. This has been happening only since we installed 2005. I haven't looked any harder but I have a feeling there are more users out there that this has been happening to.
    2006-10
    12
    I have the same problem of autosave resetting to 0 in ACAD 2008. If I find anything out I'll post here.
    150700
    3,434
    I have added this to my acaddoc.lsp (not sure what file is used for LDT, might be the same)
    (defun VTF (CALL CALLBACK)
      (if (= (strcase (car CALLBACK)) "SAVETIME")
        (progn
          (setq ALK (getvar "savetime"))
          (if (/= ALK 5)
        (progn
            (alert "Savetime has been changed, Resetting to 5 minutes! ")
              (setvar "savetime" 5)
    It alerts the user if the autosave time has been changed, and resets it back to 5 minutes.
  1. 2011: autosave
    By JLHConsulting in forum AutoCAD General
    Last Post: 2010-10-12, 01:36 PM
  2. AutoSave
    By IanR in forum Inventor Wish List
    Last Post: 2008-02-01, 04:03 AM
  3. AutoSave
    By devilfrog in forum Design Review - Wish List
    Last Post: 2007-04-05, 10:00 PM
  4. autosave
    By kthomas in forum Inventor Wish List
    Last Post: 2005-11-21, 11:53 PM
  5. autosave.bak
    By sinclair in forum AutoCAD General
    Last Post: 2004-09-07, 03:52 PM
