Thread: 2011 Beam system, tag each member bug?
    2007-03
    Rock Island, IL
    114
    Default 2011 Beam system, tag each member bug?
    When I go to create a beam system, it automatically defaults the "Tag Style" to be by System. The pulldown for the Tag Style is grayed out. In 2010 I could change it to tag each member individually, did they take that option away?
    I dont want to have to do tag-all not tagged for all my beams. Thats like 3 whole extra clicks...
    Okay, and I just loaded a beam system tag OTB, and it doesnt even tag my beam system anyway... hmmm... Help!
    Active Member TheViking's Avatar
    2005-03
    Lexington, MA
    88
    Default Re: 2011 Beam system, tag each member bug?
    Is the Tag on Placement button on the ribbon enabled? This is a toggle button that turns on/off the tagging feature.
    Erik
    2003-04
    Chino, CA
    4,756
    in 2011, you can remove the Beam System (or the truss system if you are building a truss). This makes the truss individual elements rather than a sytstem. Then you can tag the individual elements.
    2007-03
    Rock Island, IL
    114
    Snellem, I missed the Tag on placement button. Thanks for the heads up on that one!
    When I click that then it gives me the warning "Do you want to load a structural beam system tag" warning. So I HAVE to have a beam system tag loaded, cuz it wants to default to Tag Style: System the first time. Boo.
    Now I wonder if there is a way to change the Tag Style to default to Framing instead of System so I can set that up for everyone when we deploy it to the whole department?
    Don't see anything for it in the Revit.ini... I guess I'll give in and load the beam system tag in our template, heck, maybe I'll even use it!
    2005-03
    Lexington, MA
    88
    Quote Originally Posted by butlerre View Post
    This is a saved setting of the template. In your companies default template start the beam system tool set the option bar and properties they way you would like and place an instance. This should be saved as the defaults for the next system. Don't forget there are 2 placement methods for beam system.
    This should work for all structural elements.
    Erik
  1. The beam system tool should allow users to specify the location of the first beam.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-06-08, 03:32 PM
  2. 2013: Possible Glitch in the Beam System ONLY when it's Sloped in Revit Structures 2011-2013
    By mark.p.maldonado744484 in forum Revit Structure - General
    Last Post: 2012-12-28, 07:33 PM
  3. Beam system, independent of other structural member.
    By autocad.wishlist1734 in forum Revit Architecture - Wish List
    Last Post: 2011-10-10, 06:43 PM
  4. Editing Beam Extensions or slope in a Beam System?
    By thredge in forum Revit Architecture - General
    Last Post: 2009-03-24, 04:23 PM
  5. Beam system member usage - Girder to Joist
    By jbrazier in forum Revit Structure - General
    Last Post: 2008-08-11, 07:47 PM
