Results 1 to 10 of 12
Thread: First 4 characters of Layout Tab with diesel expression
    2008-02
    North Seattle
    42
    Default First 4 characters of Layout Tab with diesel expression
    Can anyone help with this? I have searched and found how to link a field to CTAB system variable. I have even found someones code to get the LAST characters of the layout tab. I need to be able to link a field to the first 4 characters and another field to any characters AFTER the first 4. An example; a layout named "3.01 Elevations" would fill one field with 3.01 and another with Elevations. Any help would be greatly appreciated!
    2004-08
    Iron Station, NC
    3,198
    Default Re: First 4 characters of Layout Tab with diesel expression
    Quote Originally Posted by jmcbride.161140 View Post
    what about using the substr command and grabbing each substring of the intial string, then passing each one to your diesel statement? I'm not very familiar with diesel, but I think it would work.
    (setq str1 (substr (getvar "ctab") 0 4)
             str2 (substr (getvar "ctab") 4))
    2008-02
    North Seattle
    42
    I know it way less than you, but I think it is missing $ to make it work? When I copy and paste your code into acad I get "Invalid Field Code".
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,051
    Chris, you need to convert it to diesel.
    2008-02
    1,141
    I'm no Diesel person...
    $(substr, $(getvar,ctab), 1, 4)
    and
    $(substr, $(getvar,ctab), 4)
    2008-02
    1,141
    Quote Originally Posted by ccowgill View Post
    BTW, with substr, you must start from 1. 0 will return an error.
    2008-02
    North Seattle
    42
    Quote Originally Posted by alanjt View Post
    and
    Thanks so much!! These seemed to work perfect!
    2008-02
    1,141
    Right on! You're very welcome.
    2004-08
    Iron Station, NC
    3,198
    I dont know anything about diesel, my thought was get the string using lisp, then convert the result to diesel, but Alan obviously knows what he is doing.
    2004-08
    Iron Station, NC
    3,198
    you are right, I mis-read the help file when I was looking up the proper syntax for substr.
  1. 2014: CUI Macro with Diesel Expression
    By ccarlson376355 in forum AutoCAD Customization
    Last Post: 2013-06-10, 08:39 PM
  2. Comparing tab name with expression in diesel
    By Phil Gravel in forum AutoCAD Customization
    Last Post: 2012-10-31, 07:46 PM
  3. Using a Diesel expression in a macro
    By barker_anthony in forum AutoCAD Customization
    Last Post: 2010-10-28, 06:16 PM
  4. Backslash in DIESEL expression?
    By christopherd in forum AutoCAD Customization
    Last Post: 2007-11-16, 08:17 AM
