I noticed on 2010 and now on 2011 that I cannot fillet a line with a polyline.
On our LT2011 we can still do this, turning the item into 1 polyline. Therefore I assume it's a setting of some sort that I cant find.
Any ideas?
Any ideas?
what about the current status of edgemode? is it on or off? (although it shouldnt matter for fillet)
If I'm working in large coordinate values, I see similar issues with plines. That's common w/ state plane coordinate systems and georeferenced drawings.
When using the command Fillet, there are several options in square brackets [Undo, polyline, Radio, Trim (Recorta), Multiple]. With the Trim(Recorta) option to activate or deactivate the Trim. When Trim (Recorta) mode is enabled, you can fillet a line and a polyline. Wen disabled then not produce the fillet (assuming, for example Radio 0).
Sorry if there are differences in the name of the options, because my Autocad 2011 is in Spanish.
I have discovered the root of all my problems that I have posted on here.
It's the AutoCAD structural detailing that was included in my Revit suite. It just has a load of bugs. I've since downloaded just plain old AutoCAD and all is ok again.
I don't know why they dont include the basic version in the Structural Revit Suite!!!!!
