Results 1 to 8 of 8
Thread: Fillet
    2006-09
    England
    80
    Default Fillet
    I noticed on 2010 and now on 2011 that I cannot fillet a line with a polyline.
    On our LT2011 we can still do this, turning the item into 1 polyline. Therefore I assume it's a setting of some sort that I cant find.
    Any ideas?
    2004-08
    Hartford, Michigan
    3,194
    Default Re: Fillet
    Quote Originally Posted by Clarence Worley View Post
    Any ideas?
    fillet is working fine on my system. I thought that there was a system variable that changes whether or not when using a fillet that the two segments are joined into a single polyline, but I cant find it anywhere.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2006-09
    England
    80
    Default Re: Fillet
    Quote Originally Posted by ccowgill View Post
    Yes, that's what I'm looking for. But I cant locate it either.
    Currently it says
    "No intersection can be found between line and polyline line segments"
    But they are both in the same plane, if I explode the pl they fillet ok and vise versa if I pline the line.
    2004-08
    Hartford, Michigan
    3,194
    Default Re: Fillet
    what about the current status of edgemode? is it on or off? (although it shouldnt matter for fillet)
    Windows 10
    Cairo - no, not Illinois
    4,766
    Default Re: Fillet
    If I'm working in large coordinate values, I see similar issues with plines. That's common w/ state plane coordinate systems and georeferenced drawings.
    Member mateo's Avatar
    2001-12
    Estepona. Spain
    34
    Default Re: Fillet
    When using the command Fillet, there are several options in square brackets [Undo, polyline, Radio, Trim (Recorta), Multiple]. With the Trim(Recorta) option to activate or deactivate the Trim. When Trim (Recorta) mode is enabled, you can fillet a line and a polyline. Wen disabled then not produce the fillet (assuming, for example Radio 0).
    Sorry if there are differences in the name of the options, because my Autocad 2011 is in Spanish.
    2006-09
    England
    80
    Default Re: Fillet
    I have discovered the root of all my problems that I have posted on here.
    It's the AutoCAD structural detailing that was included in my Revit suite. It just has a load of bugs. I've since downloaded just plain old AutoCAD and all is ok again.
    I don't know why they dont include the basic version in the Structural Revit Suite!!!!!
    0,0,0 The Origin
    8,569
    Default Re: Fillet
    Thanks for that info. Let's hope it saves other people from grief.
    John B
  1. using fillet
    By mdsalman2003 in forum AutoLISP
    Last Post: 2010-07-06, 06:31 AM
  2. 3D Fillet...
    By BeKirra in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-08-06, 07:02 AM
  3. fillet
    By asmaa.14-7 in forum Dot Net API
    Last Post: 2008-11-09, 12:26 PM
  4. Fillet
    By benoit1045 in forum Inventor - General
    Last Post: 2007-09-12, 09:22 PM
  5. Fillet
    By Kroke in forum Revit Architecture - General
    Last Post: 2003-05-07, 08:37 PM
