Thread: SP, HotFix
    Earth
    9,831
    Question SP, HotFix
    For Raster Design 2005, the following patches are available:
    Service Pack 1
    Hot Fix 1
    Hot Fix 2
    In what order should these be applied?
    Does SP1 include HF1 and HF2?
    Unless I'm blind, I didn't see any reference to this in the readme files.
    TIA
    2015-12
    Arizona
    2,478
    Default Re: SP, HotFix
    As this is not specified in the documentation
    this suggests you install them in the order of
    their release.
    Hot Fix 1
    Hot Fix 2
    then
    Service Pack 1
    13,657
    Quote Originally Posted by rkmcswain
    Service Pack 1
    Hot Fix 1
    Hot Fix 2
    Hi
    I can't find any information or reference to Hot Fix 1 for Raster Design 2005 on the Autodesk web site.... probably me being blind.
    But the Readme file for Hot Fix 2 clearly states the following -
    <snip>
    Who Should Install the Update?
    This Update can be applied to locked and unlocked versions of Autodesk Raster Design 2005 SP1 of all languages, except Japanese, running on English-language and non-English-language operating systems. This update can only be applied to a Raster Design 2005 instance to which Service Pack 1 has been applied.
    </snip>
    Have a good one, Mike
    Earth
    9,831
    HOTFIX 1 = http://usa.autodesk.com/adsk/servlet...linkID=2476535
    Although the page doesn't call it HF1, the readme does refer to it in this way.
    You are correct about the reference to SP1 in the HF2 readme. And it was clear - I was just blind
    2004-07
    Detroit Michigan
    2,508
    Good info, however I have given up.....SP is now off my system. I know there are some benefits to having SP, but I have too many software applications to spend time hunting down all the patches.
  1. HotFix Max2012
    By METANAMORPHOSE in forum 3ds Max - General
    Last Post: 2011-06-28, 02:18 PM
  2. 2011: Hotfix
    By philippe.drouant in forum Revit Architecture - General
    Last Post: 2010-10-22, 09:49 AM
  3. O que é Hotfix?
    By CARLOS.NORONHA in forum AutoCAD Civil 3D - General
    Last Post: 2009-03-07, 08:07 PM
  4. Replies: 9
    Last Post: 2007-04-12, 01:19 PM
  5. Hotfix for text problem caused by Microsoft Hotfix KB918118
    By JD Mather in forum Inventor - General
    Last Post: 2007-03-01, 01:42 PM
