Thread: Object Enablers
    2007-06
    Lansing, Michigan
    44
    Default Object Enablers
    I was recently having an issue with a Quick Pen enabler, at the time I was running NavisWorks 2011 Beta. I was encouraged to upgrade to the offical release of NavisWork 2011, at the same time I also updated the AutoCAD Architecture 2011 and Revit 2011. Once I upgraded the platforms I realized that my problem was compounded. Now all the AutoCAD MEP 2011 files from contractors will not import in as solids. When I open them in AutoCAD I can see them in 3D.
    Any ideas on what I am missing? I am sure it is something simple with settings. I am running all the systems as 64-bit on a Dell Precision M6400.
    I appreciate your help.
    Art Theusch
    Collaborative
    Lansing, MI
    www.collaborativecg.com
    2007-06
    Lansing, Michigan
    44
    Default Re: Object Enablers
    I also have installed all the latest object enablers. When I run a scene statics, it tells me I am missing the Autodesk Architectural Desktop 2007 and AutoCADĀ® MEP 2008. I have tried to download these but it will not let me install them.
    Art Theusch
    Collaborative
    Lansing, MI
    2000-01
    Seattle WA USA
    5,859
    Have you opened and saved the contractors' files in ACA 2011?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2007-08
    81
    If you are opening/referencing DWG's in Navis, what do you have "DWG Loader Version" set to (Navis>Tools>Global Options>File Readers>DWG/DXF/SAT)?
  1. Object Enablers..
    By Dr._House in forum AMEP General
    Last Post: 2012-10-17, 05:01 PM
  2. Object Enablers
    By Steve Cook in forum NavisWorks - General
    Last Post: 2009-07-29, 01:26 PM
  3. Object Enablers
    By David Haynes in forum NavisWorks - General
    Last Post: 2008-06-14, 06:47 PM
  4. Beyond Object Enablers ....
    By rclayton in forum CAD Management - General
    Last Post: 2005-06-02, 03:56 PM
  5. Object Enablers
    By phil.72896 in forum AutoCAD LT - General
    Last Post: 2004-08-18, 10:59 PM
