I've been working on a security camera family for a project that will allow you to enter the field of view dimensions (width & height) and the distance to the target and everything is working fine. The problem I'm running into is this... the camera needs to be able to point down (or up) towards the target. Right now it points straight ahead. I can rotate it in plan view but in a section it throws a wobbly. I've messed around with a rotation parameter but I keep getting a message that says it can't create the family when it's rotated. The field of view family is simply a blend with a 2" diameter circle on one end and a rectangle on the other end.
A sample project (2010) is attached with the family I'm playing around with. Any thoughts or suggestions will be appreciated.
Matt
