I am using AutoCAD2007.
We use AutoCAD very little and so our setup is probably not best practice. I am sure there are much better ways to go about this, but for now I am just seeking a "quick fix" if there is one.
Some years back I created a Title Block drawing populated with attributes. The entire title block is saved as a block in the drawing. I then inserted that block into a drawing template. Seems to work fine.
Some recent requirements are driving the need to update the title block. I think I have worked through adding attributes to the block and updating the template (wow, who would have thunk that would take hours!)
Now I am trying to update the titleblock in some existing drawings. The method I am using (because it is the only one I know of) is to open the drawing, find the titleblock block in the design center , RMC and select redefine only. This method certainly does something, but not what I expect.
The most noticable of the unexpected results is that I have a distribution statement. This is static text per project, but can change - hence being an attribute. One of the updates was to add an additional line to the statement so the paragraph is taller. When I clicked the redefine only the new statement is superimposed over the old statement - both are visible.
If I double-click on the titleblock to launch the Enhanced Attribute Editor, the attributes listed are of the old nature, not the updated. If I select the block, and click Modify/Object/Attribute\Block Attribute Editor the updated attributes are listed. I purged the drawing but no change.
Questions:
Is this method suitable or is there a more preferred way?
Should I be selecting the titleblock block of the titleblock drawing or the titleblock block contained in the drawing template? Since the template contains a copy, is there any difference?
Is there an added step I should be taking in the updated drawing?
My goal is to revisit the whole setup we have and adopt sheet sets perhaps. As I said, we don't use it much, but over the course of a couple years and several projects, it has crept into many corner of many projects. So I want to get things cleaned up to save myself even more grief in the future. But that is for another day. Right now the boss is frowning...
Daen
